Wiring schematic for the overhead console
crazykaese
91ProtoTy/IndyPaceTribute & Sawzall Master
Got one outa the junkyard - it has the back light, the two swivelling front round lights, and the LED readout with two buttons to the left of it. ON/OFF and US/MET. The back light I think I can figure out. The front two swivel lights have 3 wires - orange, grey and black. The LED readout has 6 wires - black with white stripe, brown, dark green, light green, grey, and white. Help me out - what goes where? And how do you attach the entire assembly to the roof without having to take the headliner down? I saw how the back light is held in with two studs and a round clip that slides on the studs. Do I just line up the front screw hole and drill thru the headliner? Hopefully there is a roof brace there somewhere to mount it to. Just don't want to make a mistake.
EluZioN
The mounting holes for the console should already be there on mounted supports. There is one screw in the front, two in the back underneath the dome light lense.
The front two lights and dome light run off the same plug (which you should aready have also). If you need the voltages, I can get them for you tomorrow. Two wires are 12v/ground, the other is for dimming.
As far as the LED goes, I don't know for sure but I am not aware of Ty's ever having that display. I looked for information on it because I wanted to put one in myself. That display shows outside tempature and also acts as a compass. The good news is....the compass is inside the display, needing no other wiring. The bad news is....the external tempature sensor is located lord knows where, and would need to be mounted and wired up through the headliner.
I have a few of these displays (with harnesses) from Bravada's, if anyone knows the location of the external tempature sensor/module, please let us know. My local Oldsmobile service guy did everything but laugh when I asked him for help locating it. Even more amusing he said it was located inside the display itself (think about it).
Regards,
EluZioN
Loeryder
The sensor is located behind the grill of the Bravadas.
The DRAC is the speed sensor module piggybacked on the ECM.
I forget why it needs to be tapped in to that but it does.
Theres a few threads on this over at www.s-seriesforum.com
EluZioN
Thanks for the information, I think I'll go get a sensor from the scrapyard and put mine in. I think it would make a nice addition to the truck.
Regards,
EluZioN
