Wobbling converter
TYTILIDIE
METH HEAD
So. The other day my wife complained that her truck was making a loud clicking sound. I took it for a ride and heard what sounded like the fan hitting the shroud. Sure enough, the tie down chain link broke. I replaced it and the noise went away.
Later that day, she said the truck is still making a strange noise. I go out and listen to it and sure enough, there is a strange sound. Sounded like the flex plate hitting the cover. So I take the cover off and sure enough, it was digging in to the cover. So I put the truck back and fire it up and the noise was gone but, I look at the converter and it looked like it was wobbling.
Next day, wife says she hears a strange ticking sound. I listen to it and sure enough, it sounds like a very faint knock. Maybe even an exhaust leak. I searched and searched for leaks but the more I thought about it I figured it has to be related to the converter/flexplate area. So I pull the oil filter tonight and cut it open, little to no bearing material. When I say little I mean pretty much non existent. I had to look really hard to find anything.
My thought is that if the crank were bent (causing the wobbling converter) then the bearing would be trashed by now. So I am thinking maybe a front pump bushing? Maybe a cracked or bent flexplate? I inspected the plate best I could and saw nothing wrong.
What do you guys vote for?
I should also note that, the truck seems to vibrate under initial throttle increase. There is virtually no noise when driving but seems that it is trying to bog down here and there. Oil pressure is great, DM shows no knock. Noting smoking/leaking etc.
BoostedSUV
Re: Wobbling converter
I had a flex plate crack around the bolts on my small block el camino. The converter wobbled and the flexplate would sometimes skim the bendix drive on the starter and drove me nuts for a long time. Didn't catch it until I pulled the trans one day and saw the flexplate was cracked almost around the whole circumference. Try prying the flexplate with a bar with the truck off of course and see if you can see how much movement it has.
Icarus-54
Donating Old Member
I had the same situation,mine turned out to be loose flex plate bolts,it had the same symptoms as yours.
TYTILIDIE
METH HEAD
You know I really am not a loctite fan so no. I built the motor and trans almost two years ago. I am going to pull the trans this weekend to check this out. At the very least, it will be worth it to pull it and have the lock up clutch replaced since it isn't working anymore and then I can check this thing out while the trans is out. I think today I will put the truck back up in the air, pull the converter bolts off, slide it back and look in there further. I think that way I'd be able to see cracks better if there are any. Might even be able to tell if the flexplate bolts are loose.
It's just a six
Super Member
You can also tell if the flexplate has cracks on it sometimes when you give it a wack w/a wrench or tool, if it has a dull thud to it, it probably has a crack, if it sounds kinda crisp & a riiiing to it, it's probably OK, but look for cracks as well.
Hope that makes sense.
BMFB
Not to scale
I know that loctite stuffs really expencive, and applying it is a total bitch, but you gotta use it on stuff like this. Theres to much vibration and stress to just assume things are gonna hold together forever. I thought I cracked my flex plate, only thing I could come up with was to unbolt the converter ans slide it back, and see if the plate moved excessivly, but if its floppin around and hitting stuff, its loose somewhere.
Treymen
I had the exact same issue, turned out that 2 of the bolts to the torque converter had backed off and the tc was literally wobbling.
Easy fix
Throws
I know that loctite stuffs really expencive, and applying it is a total bitch, but you gotta use it on stuff like this. ...
THIS. Loctite is a perfect use for the flexplate/flywheel bolts. Go for the high-strength stuff tho. I use a stronger-then-normal version I got from a machinist.
-P
I buy loctite in the big bottles and feel its a great insurance policy on just about every bolt that is critical. Flex plates and convertor bolts won't go in without it under my watch.
As the Doc said GM didn't do it, but they had all new items. For me its bit me once or twice before, loctite is cheap insurance for me to not be back in there.
jpalmer
If your flexplate is damaged, let me know, I have one sci approved and ran for 5 minutes. Shameless plug, sorry, hope it is easily remedied
TYTILIDIE
METH HEAD
So far the problem is that now my Ty is busted so I am going to get mine fixed up then pull hers in and see whats up. Truthfully, it has been too cold in the garage for me to go rolling around the floor so hopefully I'll get to it in a week or two.
