wont crank- after tune-up
ty
I need help, today I tuned up the typhoon, new plugs, cap and rotor. After a few hours finally finished, truck won't crank, fuel pump turns on but nothing after that. I have checked the wires, going to check cap again. Any thoughts, this has never happened before, truck always starts just fine. I pulled the wheels wells out if that helps. Pulled the ecm b fuse to clear history, think that is all. I am clueless, why won't it crank over.
Jimmy
Banned
Is the starter getting power? It could be that the purple wire finally gave up the ghost.It could also maybe be the neutral safety switch,but I'd start at the starter and work my way forward.
ty
thanks for the reply's, I have swapped out the ecm b fuse, checked the ign fuse and ecm 1 fuse, all checked out. Tomorrow I will test the starter. It makes the "click" sound and that is ist. Thanks for all the help.
velox03
is it a single click?
i've had all sorts of no-start problems.
if it is a single click... check into the starter solenoid or the starter itself.
and of course possibly the purple wire. check down by the starter itself and see if your wires are getting fried.
if there is struggle but no catch... maybe the plug wires are not hooked up right.
look under this engine tech forum and see my posts regarding "no-start" problems. i'm in the process of mounting a remote solenoid. however my engine is so ugly i decided to do a whole bunch of other things while i had everything out.
-MikeC
ty
It is the single click, nothing else. I will check the purple wire and test the starter, any easy ways. The only way I know is the big screwdriver method. What is strange is I haven't had any problems before, no hard starting or hot start problems. It fired right up before the tune-up.
SY2932
Administrator
What is the condition of the battery? Sounds like the voltage may be low if you are only geting one click...
velox03
in my situation it wasn't the battery because i turned on all my lights...
and it wouldn't dim. so at the time i was stumped. hopefully after doing my remote solenoid i'll have this solved. i had the hot-shot relay, but i'm going to rip it out. also my wires going to the starter were fried.
-MikeC
