live1053rulz
Nor Cal SyTy
So I've finally brought myself to post a new thread. I can't figure out why my truck won't make more than like 12 or 13 psi max boost. I never thought I'd have this problem because before I did this stuff I was overboosting to like 20 psi. I'm running the RPM A2A kit and using a "Boostvalve" for current boost control. I've adjusted the wastegate so it should be making full boost. I can get it to go up to 10 lbs pretty quickly, but doesn't go all that much farther. I want to run more boost and hopefully make use of all these mods I've done. I'm still on the stock turbo/wastegate/downpipe but I've read all about a lot of you guys going real fast on all that stock stuff. Also, no matter how I adjust the Boostvalve, it doesn't go any higher, even all the way in. Any suggestions appreciated.
