MyTy
Hoping I can get some feedback before I start throwing money at my problem.. So since the purchase of the truck I have had some stalling issues and occasional no starts.. the rare times it would no start on me, once I started jiggling the key around and turning it at the same time it would start. So I did research and the problem most likely was the ignition switch on the column.. at least that's the best I could come up with.
So I replaced the ignition switch and things were better for about a month or two and than the common stalling issue arose again. It would die when I came to a stop or going from drive to reverse. sometimes even when just letting off the gas while at freeway speeds. I recently replaced the cap and rotor and things got about 50% better but it was still occasionally stalling. I could see the distributor its self had seen better days when I did the cap/rotor so I installed a new distributor. After seeing how bad the old distributor was I thought for sure this would solve the problem. However things are worse now. I cant drive the truck without keeping my foot on the gas. I'm serious about that.. now I have to break with my left foot gas with my right.. when I come to a stop if I don't keep idle at about 1200 to 1000 rpm it dies.. when I cold start it it idles fine.. after warm up it wont stay at idle. it starts than dies rite away.. A mechanic I know thinks its the fuel pump for sure.. before I purchase a fuel pump for it I was hoping to get some feedback. Thanks guys!
Ive searched posts but nothing really comes up as far as having to keep your foot on the gas for it the engine to stay on.
