WOT Fuel Pressure testing
TYTILIDIE
METH HEAD
I am going to be doiung some WOT FP testing tomorrow and was wondering what I should look for in terms of where the FP Should be. I am all stock excpet for the GT30 wheel in the turbo. Also have 2500 stall. I just bought an AFPR so i will be trying to dialit in w/o DataMaster cause my laptop screen took a shit. Any help is appreciated.
Mike
0966Sy
Code what?
Re: WOT Fuel Pressure testing
If your running 45psi base and your running 25psi of boost your fuel pressure at 25psi should be 70psi. Add 1psi fuel pressure to every psi of boost counting from base fuel pressure.
TYTILIDIE
METH HEAD
I see. As far as I know the boost will still be 15. Or will it go up just cause of that wheel on its own?
At WOT, wont the FP drop some? Are you saying that a WOT test isnt necessary? I would think htat at WOT you would start to drop pressure cause youre using more fuel.
Mike
jwaller
Evil Genius/SyTy Guru
Mike
boost pressure is controlled by the wastegate. you could have a 105mm comp wheel and still run 15psi, it's all a function of the wg system.
