would this engine bolt in perfect?
I would cut out your crossmember so as you drop it in the top it falls out the bottom.
Yes it will bolt in, how long it lives and how well it runs is something else.
MRKING
New Parts for Old Trucks
Drop in motor question
I would suggest this first , that bravada motor wont hold on under boost .
-complete typhoon motor from upper intake to exhaust manifolds with progate on the crossover. It has roughly 70k miles and runs excellent. $1500 obo.
These prices do not include shipping. If interested in something, lemme know and we can work out a deal.
thanks
jordan
tealty@hotmail.com
Sy769
Whatcha gonna drop it in?
IF a syty is the answer yes it will work.
Main problem is you won't be able to run much boost due to the high compression.
Some people say the late model balance shaft block is weaker. Probably is but who knows what the limit for it is. They are smooth though.
If you want to run any kind of boost you would have to put in low compression piston and good gaskets. Also the heads would have to be drilled and intake manifold welded up.
