TN WTB: Brodix V6-8 heads
T-Bone
Re: WTB: Brodix V6-8 heads
Eric, I have a brand new set of Brodix "Lingenfelter" worked heads for a V6 block. Never even bolted to a bare block yet. Sold on here for $2500 but doubt I will ever get around to using them. If you wanna check them out, let me know.....I'll treat you right on them ;).
SPECS:
Angle Plugs
68cc chambers
New 2.05” intake high temp SS Valves
New 1.60” Exhaust high temp SS valves
New Comp Cams Beehive Hydraulic valve springs
RA50 deck finish for Cometic MLS Gaskets
These will also fit a stock intake. These heads are one of the best setups for a built hydraulic cam motor. The Beehive springs are advertised as:
"Street/Strip.- Increased Valve Train stability and lighter. Best possible choice for street/strip. More aggressive for strip and retains durability for the street. Originally designed for LS1, LS2, LS6."
This is not a set like people normally buy on Ebay from the circle track guys. These have been gone through, updated, and ported ... with new parts that we need for our turbo motors. You can go to around 300 cfm on the porting, but its really not warranted unless you are going with a solid roller cam setup. This is setup for 422 or similar hydraulic cam setup. A stock intake welded up for vortecs will fit this intake with a 1203 gasket. These are a great street/strip aluminum head setup. Without the cost of the rockers and valve covers these heads are not much more than a new set of built vortecs and more than a grand less than a new Brodix set.
Head spec information.
Brodix -10 Lil Brodies
Chamber Volume: 68 cc
Intake Port: 210
Cylinder Valve Ported
Port Lift Corr CFM
Int #1 @0.300 =197
Int #1 @0.400 =241
Int #1 @0.450 =249
Int #1 @0.500 =257
Int #1 @0.550 =269
Int #1 @0.600 =278
Int #1 @0.650 =284
Exh #1 @0.200 =112
Exh #1 @0.300 =142
Exh #1 @0.400 =174
Exh #1 @0.450 =186
Exh #1 @0.500 =195
Exh #1 @0.550 =204
Exh #1 @0.600 =208
Exh #1 @0.650 =214
Head information:
Make: *90* V6 -8 23*
Valve Angle: * 23°
Plug Angle: * Angled
Spark Plug : * CHAMPION RN12YC or AUTOLITE 3924 - for Pump Gas
Spark Plug : * NGK R5671A-8 - for Racing Gas
ARP Head Studs: * ARP 234-4301 (V8 KIT)
Head Gaskets: * Cometic MLS, RA50 finish
Heads Torque: *80 ft-lb with moly
Rocker Studs: * Brodix 3/8", -AR RRS-4H
Rocker Studs Torque: * 40-45 ft-lb
Valve Guides: *Bronze
Intake Valves: * Ferrea SS, High temp, 2.05 x 4.965 o.a.l.
Exhaust Valves: * Ferrea SS, High temp, 1.60 x 4.965 o.a.l.
Valve Springs: *1.445 Beehive Hydraulic Roller Valve Spring - CC26120-12
Valve Springs Specs: * 140 lb Closed, 345 lb Open @ .600, 2.01 installed Height,
Retainers: * 10° - CCA-795-12
Valve Locks: * 10° Jumbo - CC 611
Valve Seals: * 11/32 - US VS529V
Intake Gaskets: * FEL-PRO 1203
Valve Cover Gasket: * FEL-PRO 1601
Exhaust Gaskets: * FEL-PRO 1403
Windedv6
Ty n 10s
I will vouch for these heads. This is about as good as you will find for our setup. Anything less than the price quoted is a steal as it would cost you much more than this to have a set done like this. This is the same head as the -8 except that Brodix ported the runners slightly in the -10 heads.
John
T-Bone
Eric, I have another guy wanting these. Only fair I give you the opportunity to buy since they were placed in your thread. If you don't show interest within the next 24 hours, I will let them go to Justin. Just wanna be fair and keep everything in the open since I have nothing to hide :tup:
sy605
I'll pass. I picked up some new bare heads on the low. Thanks for the hookup though.
:tup:
T-Bone
Heads SOLD. Thanks Justin!
.....and thanks, Eric. Didn't intend to transact with another member through your thread but such is life :).
