WTB mild upgrade bolt on turbo
leudakris
I've seen a few other posts about this, but still would like some insight from the experts here.
The stock turbo on the Ty I just bought has some shaft play, so its probably worth looking into a replacement. I wouldn't mind a bit of an upgrade, maybe a 20g, but it doesn't seem too easy to find the 20g with 14cm exhaust housing other than turborcharger.com for 1200. Looks like forcedperformance has the same deal for 1250. Other options are for the bolt on garretts from RPM for similar price range (not sure how they compare to the 20g). Then there is the kinugawa option, which price-wise seems promising, but I have a few issues, first being that their exhaust housings appear to only come in the stock (8cm) size, even for the 60-1 compressor version.
I'd rather not send my stock out for re-work, thought I'd be willing to send it back as a core after the swap..
Otherwise I'd be happy to get something from someone else that might have an option for less $ If its going to be 1200, so be it, Its just my impression folks are finding much better deals...
Thanks!
Black Knight
I Glow Therefore I am
Re: WTB mild upgrade bolt on turbo
If I were you and don't have an exact turbo you want in mild just find someone with a cheap used stock one. It will make plenty of power to start out with.
leudakris
thanks, this makes sense. I was thinking depending on price, maybe the kinugawa (new) might be an alternative to a used stock if the price was similar, but I'm interested in that stock option if anyone has one.
Another thing to mention.. I'm having a rear main seal replaced, and at the same time, I have a 2600 stall converter I'm probably going to have put on at the same time...
Yukon Jon
i have a stock turbo just rebuilt, with about a 1000 miles on it no shaft play! 400 obo
Syclone22
I have a brand new OEM SYTY turbo for 1100 US but
it is in South America so shipping cost will be a bit higher
if you are interested shoot me a reply !!!! :tup
Black Knight
I was purely looking at it from a cost and ease of overall installation perspective, not what our motors should have came with. I'm pretty sure most agree a larger exhaust housing should have been in order from the get go.
leudakris
Its just a Six,
I think that those Kinugawa's you have linked probably come from the same supplier as on ebay (using the same pics and marketing.), The ones on ebay have more specs listed, including the 8cm exhaust housing. I asked the seller (via ebay) if there is any chance of a bigger turbine, and they said they could only offer a 10cm v-band style (so no longer bolt on).
I'm leaning toward one of these (yes the whole thing Mike :) ), but I'm still concerned with that 8cm. Should I not be so concerned perhaps? I mean I'll get the stock spool but not get as much top end right? not sure that i'm too concerned there...
It's just a six
Super Member
Yes,
I got the same response. I asked also. Here is the 10 CM housing http://www.ebay.co.uk/itm/Turbochar...CarParts_SM&hash=item1c24b499fa#ht_939wt_702?
It does have the larger "H" turbine wheel, so it should flow a bit better than a stock turbine wheel w/a 8 CM housing.
You could try & open up (port) the 8CM housing as much as possible to increase the exhaust flow.
All the prices are the same for a 60-1 wheel or a 20G wheel, or stock size turbo, IMO, I would get the 60-1 turbo, later you could always find a 10,12 or 14 cm turbine housing & install that.
If you are runing a stock torque converter, you will like the 8 CM turbine housing, it will spool just as fast as the stock turbo, but once it get's into boost it will boost faster.
leudakris
So be it (and thanks everyone for the input and offers),
I'm ordering a kinugawa 60-1... maybe try some porting before the swap.
It's just a six
Super Member
Raist103
fyi i have a stock turbo built by jwaller with a 57mm trim wheel. i picked up .6 in the 1/4 on my last truck with one.
Raist103
yeah. i already had an ultimate chip with 3 map bar running 18psi. just a direct bolt on.
T-Bone
I have a used performance turbo that works fine but needs rebuilt (some shaft play). I bought it from a member on here who was parting out his build but I never have installed it. $225 shipped and I can post pics and details if you are interested in it. Guessing a rebuild would run $250-400.....never had one done so I am guessing at best.
TYTILIDIE
METH HEAD
Just curious, did you just change the turbo & nothing else? No tuning, no boost increase?
Same here when I had Wallers 57mm stock turbo. Except I was on stock chip. If you want a 20g with 14cm housing you may want to contact Jwaller and see if he has any. He always did when I needed one.
Does this 60-1 Kinugawa come with a 14cm housing?
killa66cam
RIDIN DIRTY
I am interested in the turbo info and pics. Can anyone else chime in on the price of a rebuild? Thanks.
Cam
