cvcsmkr
The freaking problems with this truck is getting real old. I am just so sick of having a different problem every week. I hope i am not the only one having so many problems. Well i dont hope for the same misfortune to others i would just like to know that i am not the only one getting screwed.
Anyways here is my newest daily problem. it was just slightly revving by itself. Of course i didn't have DM with me. the rpms would not go below 1k in drive, idling. while the rpms were up to 1k, the idle speed(in drive, no brake) was much faster than before, so it took more to brake. if i put in park it would idle normal(700-600 rpms). While in park i revved it a little for problem to surface, the truck started revving to about 2k byitself a few times, it didn't do it again. I was having the exact opposite problem a few days ago.
From previous threads:
4-12
i noticed yesterday when the truck was idiling for 10 min or so, the idle rpm would drop to around 500 and it would be real rough then rise back to about 1000 and the CE light would flash. then when it was time to put it in reverse the motor would stall. after backing up and putting it in drive it stalled about 2 more times. again flashing the CE light when the rpms got real low. it is also sputtering pretty bad on part throttle just driving aroung town. if i am going thru a parking lot or something maybe about every 4 times i touch the gas peddle the motor will rise in rpms to about 1500-2000 then it will just sputter and not accelerate about 3 seconds later it will be fine. I haven't gotten DM on it yet but i know this is going to be harder than a WOT problem. This has been going on for 2 days the first day not as bad but when it thru the CE light it stayed solid, until yesterday. fuel press is good, base of 50 and rises with boost.
4-17
Will i hooked a multi-meter to cigarette socket to check my votages. Last night it was doing the low rpm thing(see below). As the rpm would drop to 500 or so the meter readings would drop from a steady 13.8ish to 12.xx. On anther note i was doing some runs with DM. And i was getting about 16 KR @ 19 psi. So i cut the boost to 17psi and i was still getting 6*KR. So i think i just need to bring it down to 15. Are these 2 different problems. What could be causing the rpms to drop like so?
Also i haven't thrown any CE lights since the first time.
4-12
4-17
