XFI FAST Injector Firing ?
gt67sy
I don't know if any of you guys have had any time with the XFI FAST unit or if it is even the same for the old FAST units. I tried to fire my truck tonight with the XFI and i have spark and fuel to the rail. The injector lights are flashing on the XFI unit but they aren't actually firing. In the instructions they say if you are using a race style low impedence injector that you have to install a relay to up the amp/volts to the injectors. I am running the 75# injectors so I am thinking I fall into this category. Has anyone run across the same problems was this something that had to be done with the old fast units also. If so what kind of relay is it?
Try Me
Re: XFI FAST Injector Firing ?
I have the older fast system now with 84lb injectors and dont have any kind of relay. it goes straight from the injector harness to the ecu connector.
Kinda off subject, but did they have a chassis harness adapter for the xfi like the older system to go into a sy/ty? I am selling my older system and going with the xfi for my lq9 engine swap...
4C FED
Absolutum Dominium
Who did the injector wiring harness?
I know with the previous FAST there was some discrepancy with wiring the injector harness.
WindedV6 helped me get mine wired correctly. I would imagine that it would be the same for XFI and previous generation FAST.
