Xylene injection or mix?
James Thomas
"NO CLASS"
Ok boys it's late and I can't sleep due to the chili burger induced indigestion so I'm just burping out loud here.
Anyone ever try Xylene in their Alky inj. system or a Alky / Xy mix (Hmmm... that could be funny, a truck addicted to X :rotf: )? Any thoughts good bad or ugly? BTW, while I'm thinking about it, can the mix ratio be changed to get better than 100 octane when mixing with 93 pump gas?
TIA
___________
James
Daryl H
Re: Xylene injection or mix?
Xylene is a harsh substance to run alone. Not only will it dry out rubber o-rings but it is hard on the pump since regular gasoline is like a really thin oil which helps lubricates.
The only pump that could run Xylene would be one that could run denatured alcohol like SMC.
But that is just my guess since no one does this that I know of.
cameronsclone
you could try making your own concoction, adding things to even out the impurities, marvel mystery oil is good for lubrication.
Loeryder
You can also add Uplon fuel lube by Klotz.
That's what SMC suggests for lube.
turbodig
TIA
___________
James
Why not just put it in your gas tank... same effect, and you don't have to deal with distribution issues.
30% mix seems to be the max that does any good. After 20%, the gains get smaller and smaller.
A properly tuned/set up alky system will make the slight octane bump of xylene a moot point. Further, it's tougher to tune against xylene, as your formulation is always changing.
James Thomas
"NO CLASS"
Thanks Mr. Dig, that was what I was looking for!
_________
James
Lynn D. Brown
Gasoline 101 - I don't think U want Xylene in an injection system. In your gas tank maybe, but it's too heavy for injection. Benzene, Toluene & Xylene (BTX) are your basic hi Octane Aromatic compounds that are in Reformate, which is one of the basic gasoline blending stream that boosts the octane. They are also great solvents and can be used as injector cleaners. In premium, probably ~ 20-40 % of the gasoline is typically Reformate. Benzene has been reduced to almost nothing in gasoline because it is carcinogen, so Toluene & the Xylenes are primarily what is in Reformate. They all have ~ 108-115 Research Octane.
Alot of racers have added up to 20 % of Toluene or mixed Xylenes to their gas tanks to boost Octane and I've done it myself, and it does work. Alot of people use a Xylene mixture because it used to be easy to get in a paint store. Not sure anymore because Air Pollution restictions may be phasing it out along with solvent based paints. The Xylenes are heavier than Toluene and are on the heavy end of gasoline, so Toluene is better and U can get it, probably at Solvent distributors, in bulk.
In an injection system, U want something that does 2 things, cools the incoming mixture and has high octane. The alcohols have similar Hi Octane as Aromatics but boil at a lower temperature and will therefore evaporate when U spray them and thereby cool the incoming air in addition to adding an Octane squirt. Your racing gasolines tend to have alot of Aromatics and sometimes alcohols in addition to Alkylate to give them their high octane.
