Z , W cranks are they the same
TurboJunk
questionable
I need a crank for my motor i have a complete 92' CPI sitting aorund can i use the crank out of it? or do i need a Z coded motors crank?
Re: Z , W cranks are they the same
I was wondering about this too. I've considered building an old CPI engine with the SY intake and accessories. The compression is a little higher to start with and I wouldn't have to go to a bigger turbo for the same results.
Am I dreamin or is this a logical possibility? Are there any major drawbacks or broken bridges that I will have to get past for a decent build? Surely someone out there has tried this before?
jwaller
Evil Genius/SyTy Guru
it should be fine, I've used cranks for all the different motors without fail.
critical
meltdown
The camshafts in the "W" motors are .580" shorter than the "Z' cams so a custom cam would be in order.
Cam this, cam that, cam cam cam.....
blk97ta
i have a semi new crank sitting in my basement ! it came out of a crate motor with less than 2k on it wristpin gouged the block gm put another engine in it ! everything looks new . i wouldn't even polish it ! let me know if you're interested charlie :tup:
Aren't the specs on the "W" cam pretty close to the popular 412 ( think that's it) cams that SY's use for a mild upgrade? I remember reading a thread about it awhile back that had all the specs, that's what gave me the idea. I'll have to do some searching tonight.
critical
meltdown
The w motors use the balance shaft, so the cam has to physically be shorter to accomidate the extra gears behind the timing set. As far as the cam specs.{lift&duration} i couldnt tell ya brother!
good point though.
good point though.
I found the specs... Lift is close but a little less however the durration is the same as the 412 Here is what I found...
Intake.....(stock "W") ..... (popular 412)
lift................... 0.432 ..... 0.500
duration......... 0.208 ..... 0.206
Exhaust.....(stock "W") ..... (popular 412)
lift...................... 0.440 ..... 0.500
duration............ 0.208 ..... 0.210
It seems to me that using the stock "W" cam and short block would yield similar results as a SY upgraded with the 412. Now to research the output of slightly modded SY with the 412 cam and say... vortecs. With higher compression in the "W" I'm guessing that performance would at least be the same if not more with the same turbo.
This build idea is beginning to look prety good expense wise. Thus far... it looks like I'll be building a "W" engine and accessorizing it with SY parts, stock turbo, vortecs and the basic "12's for $1K" mods. Of course I'll have to beef up the bottom end as well. I'm hoping to have similar performance at a fraction of the cost.
Anybody care to guess what my 1/4 times might be? Hope to cut 1.5 - 2.0 sec off the stock times but it won't be for at least another year before I find out first hand. Hopefully it'll make NATS '07.
bdydrpds10
Yes I drive a Typhoon.
Have you built the motor yet?
I am very curious of the build. My ty is about ready
for a rebuild.
