Z06 Machine Grey
4C FED
Absolutum Dominium
Re: Z06 Machine Grey
:tup:
I have something similar on my Syclone except no rivets & no machined finish.
Personally, the only thing I don't like on those are the rivets.
hardtailcfl
:tup:
I agree with you on the rivets. I have never been a big fan but they don't look as obtrusive to me on this wheel for some reason. Do you have any pictures of the one's on your Sy?
4C FED
Absolutum Dominium
Yeah, here is the jumbotron size:
bezerk
if been asking myselve this for quite some while.. i see you have the rear brakes set up different in the back ..normally in the back the pistons/calipers face forwards car right?? why did you do different end what is the effect of doing it that way?
4C FED
Absolutum Dominium
I have no idea.
But since the front calipers were at the rear, I wanted the back calipers to be mounted similar.
Ah, I think I remember. I'm pretty sure there was some clearance issue with putting the caliper at the front. Specifically, there was some problem with rotating the LS1 backing plate so it was upside down
evberger22
BOOSTYD
What size of wheels are those in the picture? what tire size is that? what is the offset? did you have to run a spacer?
NJSERRANO
If you don't mind me asking, why don't you guys just run stock size Z06 wheels with proper height tires? Is it because of the 18/19 combo? Or the special wheel finish?
