Zeitronix WBo2 Questions
newtyguy
Im looking at buying a wideband and was considering Zeitronix setup but their website doesent give a few details about the sensor so i figured someone might know. does it have a narrow band output so i can wire it to my ecm? and is it compatable with datamster? has anybody here used this wb02 and had good sucess with it? any info would be awsome, if you have recomendations as to a better selection for a wb02 let me know.
Thanks,
Dan
cloneman315
Re: Zeitronix WBo2 Questions
the fjo is really sweet pricey though, i use the plx m300 as many on here do it works perfect and is right on the money,and yes u can datalog with datamaster u just need to make up a chart.
newtyguy
yeah, i was considering a plx but ive heard both good and bad about them, and i really dont want to use the lm-1, i dont like the big bulky display unit or that it is really designed to be used then removed, not permently installed, and that you have to manually heat up the o2 with your cig. lighter plug ( which doesent work, not that i would smoke or let anybody smoke in it anyways) berfore every time you use it.
SY#2910
Banned
I am running the Zeitronix. I run tuner pro but have not got it intigraded yet. There is a one wire hookup for the narrowband sim for the stock computer.
