mmvic
The truck died on me a couple of weeks ago while driving. When I pulled over and tried to restart it my fuel pump didn't prime. I checked the fp gauge on and no fuel pressure. I checked the fuel pump relay and ecm b fuse both good. I tried jumping the pump with the pig tail and nothing. BTW this is a 4 year old walbro pump, and brand new fuel filter.
When I removed the pump I tested it by hooking it up to the battery and it worked. So now I thought it is a bad connection in the sending unit. Bought a new one,installed a new pump and tested to see if it would prime with the key turned. It did, numerous times. Thought the problem was fixed until I bolted everything up and let it idle for 30 seconds... Died again, same problem still, zero fuel pressure, does not prime.
I checked the ground on the frame by the the tank and it looks good same for the one up front under the radiator hose. Fuse and relay are still good.
PLEASE I am stumped and need suggestions on how to track down this issue.
Thanks-Matt
Thanks-Matt
