ZO6 centercap...
the baPhoon
I know ive seen it discussed, but the search function let me down this time heh.
Of course the front centercaps dont fit over the stud. Whats the most common fix? Cutting wheel/plasma cut off a 1/4 inch? I was thinking about trying to sand the centercap but i think the material is too thin to make a difference unless i sand totally through the damn thing.
4C FED
Absolutum Dominium
Re: ZO6 centercap...
Don't sand the center caps, cut the threaded portion sticking out...
Brute force method = hacksaw. Time = <5 min/side.
SYO237
SyTy Registry
I wouldnt use plasma. You need to make a clean as possible cut if you ever need to remove the CV axle nut in the future. Hacksaw, sawzall, or grinder with a steady hand is the best bet.
Something that might help, wrap a piece of tape around the threads and expose what you want to cut off. The tape will give you a good guide and keep you straight.
the baPhoon
I was thinking about the angle grinder/cutoff wheel.
The only sawzall i have access too is a POS.
Hmmm.. i did just remeber i have access to a rather nasty metal hacksaw. Well fellas thanks for your assistance. Ill have pics up soon.
the baPhoon
Yeah i just did it with a hacksaw and a metal cutting blade. Kinda got it at a wierd angle but it works and the centercaps fit awesome.
