ZQ8 Swaybar install (Part# ?'s)
JustDSM
Turbo & AWD whore
I've just picked up some ZQ8 sway bars (front and rear) for my '93 Ty and while they came with all the mounting hardware, I wanted to go ahead and upgrade/replace the bushings with some Energy Suspension parts while I'm in there (I'll be rebuilding the front end as well). Does anyone have or can put together a list of Energy Suspension part numbers that are known to work w/ the ZQ8 bars? From my research the front is a 33mm bar and the rear being 23mm. Would this be correct?
I'm also in need of the rear end links to attatch to the frame. What legnth/size have you guys used? Again, if you could provide the part number, all the better!
And not to get picky, but if you could list the parts in black that would be icing on the cake!
Thanks a bunch!
