Syclone#1992 said:1. Shift Truck into Neutral while stopped.
2. Press down on brake, and give the motor a couple of revs.
3. Feel brake go all the way down to the floor....
4. While still depressing brake, shift truck into OD.
5. While in overdrive, proceed to building 4-5PSI of boost.
6 When at 4-5 PSI let of brake and floor it.
Warning: This is VERY hard on the stock tranny, and other driveline parts....
TookyCat said:Aw don't take the fun out of it, this type of launch is the main feature of the whole trucks!Me and a local Syclone buddy got about 2000-3000 launches out of our trucks (no fooling) before the stock trannys failed. Your mileage may vary... But I just didn't want this guy to feel like it's a neutral drop or something where if you do it 5 times, your tranny will experience certain failure.
If your truck hooks at 10-12, yes.stashisclay said:why only 4-5 psi at lanch? Wouldn't 10-12 take off a whole hell of a lot quicker??
Not in my truck.CAMSTY said:Putting it in D vs OD is worth a tenth or better at the track too!
I can hold 4-5 PSI w/o doing the revs in N. Mine like it better with more PSI and the rev to hold the brakes.stashisclay said:why only 4-5 psi at lanch? Wouldn't 10-12 take off a whole hell of a lot quicker??
