16 n 1 chip
Osmosis
I've a 91 Z 28. I have burned chips via the craig moates software and used the G 1 addapter. However, I only put one bin on each chip. Can someone help me put the 16 n 1 ultimate chip program on one chip. I have the bins for the ultimate chip.
My wife went out and bought me a typhoon! I could not beleive it!!! A typhoon has been my dream car for the past 10 years. I can't beleive it.
Now, I have the opportunity to get an ultimate chip setup, but it's programed for 50lb injectors. How do I burn the 16 bins on one chip so I can run the stock injector setup?
I like how you can see in the gauge pod the program your running and the ease of choosing programs via the ultimate chip.
so....how do I burn the bins onto one chip?
I have the pocket programer 2.
Thank you all!
Tooky
Serious about performance
Re: 16 n 1 chip
I posted a bit of Ultimate Chip history on my website, along with the Ultimate BINs.
In my experience the Ultimate chip (I have the Radar box style, not the newer Gauge style) doesn't work with Flash EEPROMs. Search this forum for "eeprom" and you'll find my posts on the topic. The only way I've found the Ultimate to work is with old UV-erasable EPROM chips, and Moates doesn't have any of this old-school stuff. I tried burning an Ultimate 256KB BIN to a Moates 29F040 32-pin chip with my Moates BURN1 and it resulted in a lot of check engine codes and random intermittent ECM reset.
Burning and editing 16 different BINs would be a real hassle anyways, I would suggest either burning 1 at a time or getting a Moates Ostrich emulator.
Osmosis
Re: 16 n 1 chip
I tried to burn a few of the ulltimate chips on to 3 of my at29c256 chips. All chips resulted in my check engine light coming on, high idle. I did not even try to run the car. I was using my Craig Moates G1 adapter and I couldnot figure out why it was not working. I also have a 3 bar map and I was unable to use the darn thing at all.
I have an opportunity to buy an ultimate chip gauge style but it's set up for 50lb injectors. Who could burn the chip so it was set up for the stock typhoon with the ultimate bin's in it?
I've no idea of how to acomplish this, all I have is my Pocket programer???
Re: 16 n 1 chip
The individual Ultimate programs are 16K .bins, you have to offset them 4000h or Double the bin up.
The 50# program chip will need to have a display chip in them as (actually PIC controller)
turbodig
Re: 16 n 1 chip
29c256 is a 32k device. The ultimate "positions" are 16k. The whole ultimate is 256k.
Do the following from a command prompt:
copy /b my16kbin.bin + my16kbin.bin my32kbin.bin
Burn the 32k bin.
You're making the assumption that the ultimate you're buying is going to make it run better... I wouldn't necessarily make that assumption.
If you just got the truck recently, the *last* thing you should do is put a chip in it right away. It more than likely has a lot of little issues that will need to be cleared up before you can safely change the chip.
Osmosis
Re: 16 n 1 chip
Well, I understand why my 3 bar map is not working, I need a chip that will work with the 3 bar map.
My typhoon runs fine. The only issue it has is the ZR1 wheels make it really hard to drive in the mountains as it wants to grab any little grove in the road. Made for 5 hrs of white knuckle driving!
The multiple bins on one chip is a bit over my head @ this point.
Re: 16 n 1 chip
What is your current alignment specs? Condition of the bushings?
