If your changing the face-plate behind a 120 MPH speedo, no amount of DRAC messing is going to make it right. You might get it right at ONE indication but it would read high or low on each side of that one calibrated indication.
OK. I thought about this some more in the shower just now.
The 'scale' for the 160 over the 120 is 33% less pulses needed, anywhere on the scale. So I was wrong. It happens. You need to reduce the pulses by .33 That's a lot, and I'm not sure the DRAC can accomodate that with all ratios and tire sizes. But the speedo will be accurate at all indications. I was wrong.
The odometer will read .66 miles for every mile traveled. It will make your MPG calculations look terrible, but will keep the truck "low mileage". I doubt dual-DRACS can be made to work. There's only one wire to the cluster. It feeds both the speedo and odo.
Dave
I'm following ya Dave, but if it's John's drag truck, I'm guessing he doesn't care much about the mileage.
Pin breakdown here:
http://614streets.com/drac.html
If that's the real case then anyone who buys a truck with the cluster mod done for more mph should really question the exact mileage of the truck.The odometer will read .66 miles for every mile traveled. It will make your MPG calculations look terrible, but will keep the truck "low mileage". I doubt dual-DRACS can be made to work. There's only one wire to the cluster. It feeds both the speedo and odo.
Dave
