SyTyAddict
The Prototype Sy has lots of false knock at idle and driving, ranging from about 2-8* at idle. I logged at boost launch on tunerpro, and it peaked at 12.6* at 20% tps (still under vacuum) and levels out to around 8-11* throughout the run. Knock increases off idle, then decreases and levels out as rpm climbs. It has a built motor and trans with pro magnum rr, cam, atr headers, forged pistons, stall, etc. I'm pretty sure the knock comes from the valvetain/built motor.
The truck runs very well, but would run much better if it wasn't pulling a ton of timing. It also bothers me because it could be masking a lot of real knock that is covered by large amounds of false knock.
Does this amount of knock sound normal with a built motor and is it possible to fix it, while still having the sensor function for real knock?
Thanks
Thanks
