2 bolt: what can it stand
BMFB
Not to scale
so, im building this motor, and to 4 bolt it is super pricy, so i was wondering what a 2 bolt could take, taking into consideration it has arp main bolts, h beam rods, and forged pistions. im running code 59, and have no detonation issues
Quickstop [UK]
Combating adversyty.
Re: 2 bolt: what can it stand
super pricey? how so?
That's $200 tops, including the billet caps iirc......
Be a shame to skimp on that after all the other expense of the rods, pistons and other work etc.
In answer though, 450 you might start getting nervous. I know there are people on here that have gone very fast on the stock blocks though so it's all in the tune.
Question is, do you feel lucky? Well? Do ya?!
turrrbo6
Billet caps and having the machine work done for $200.00.....that's cheap.
turbodig
Unheard of, actually. I couldn't even approach the machine work for that.
Curious, if you don't have detonation issues, why are you rebuilding your motor?
Foot Performance
Splay caps would cost closer to a grand were I come from. If you not going to spend the money there I wouldnt worry about making enough power to hurt it.
If it was me I would spend the extra coin on the bottom end and upgrade heads later on down the road
Quickstop [UK]
OK so I totally underestimated this...
$270 for the caps from RPM (I have them and my builder said they were very good quality)
machine work on top....
$700 for labour? Seems excessive though..
Sorry for the misinformation.
BMFB
Not to scale
i lost my front main to a bad pressure spring in my oil pump. to get the machine work and caps done its about 8 to 9 hundred dollars with the line hone, and even with a set of vortech heads 450 seems like a high number have to worry about, if i had an extra gand right now id concider it though, lol. but really its just a stock build with nicer parts. same cam, same compression
Foot Performance
That is why I think you will be fine with a good tune. but is 6 month or so when you want more power you will wish you would have done it properly:2cents:
