20g actuator questions?
MySaudi
TD06H-16G actuator will work on a TD06H-20G??
what do you guys think?.. will this work out fine with the internal wastegate in the 20g?..
MySaudi
Re: 20g actuator questions?
anyone?.. know if this will work for me to not worry about blowing the motor..
jwaller
Evil Genius/SyTy Guru
it will work but it wont bolt up without some mods. they are not the same bolt pattern or flange. but same base boost pressure.
NJ93TY
I run a stock wastegate with a 20G for now. Got a bracket made by Renz, had to modify it but it works.
MySaudi
would I just have to drill a hole to make it fit like some people do with the stock actuator?.. or will I have to get a piece made?
turbodig
You'd need a drill a hole, and bend the rod part of it slightly in a vise.
As long as you adjust the rod properly, you should be able to get back to stock boost levels.
You'll still need to monitor knock with something. Stock boost levels can ping like crazy if things aren't right.
jwaller
I would use the right act. the rod's and brackets are different. it can be made to work but for me it's easier to find the right part.
MySaudi
well i heard that you have them on your website.. when I try to go onto your website i can't find it..I thought you sold them for like $105 or something?
MySaudi
How would I know what part of the rod to bend?.. Drilling a hole and bending a rod slightly wont be a problem if I know where to bend it and how much..
jwaller
my site is no longer. I waited a day late and somebody bought it and won't give it back.
I can get you what you need and its way cheaper than 105. pm me for details.
