20g14cm vs. T-44
attackdog
Hi all. I currently have the 20g14cm ported turbo on my current build. I have aquired a Precision T-44 turbo that needs a rebuild. What are the advantages, if any, to going into the T-44? Thanks.
-Dean
turbodig
Re: 20g14cm vs. T-44
-Dean
You might pick up a couple MPH in the deal. You've got a sizeable converter already, so that won't be a problem.
Bottom line, though, the really fast TE-44 trucks are within a tenth or two of the 20g trucks.
Not to mention, you'll need to do downpipe, etc. to make it work.
Depending on what's wrong with the turbo, you might need the center section, which is pretty close to the cost of a new turbo.
