3 bar map sensor
Syclone1682
hopefully someone can help with this one. I have the stg ultimate chip and the 3 bar map sensor. The stg packet I got with the chip says one way to make sure your 3 bar map is working correctly is if you stay in the green (vauccum) part of the stock boost guage when entering boost. For some reason I will enter boost and it will read as vacuum on my stock guage. Then maybe a week or so later the stock boost guage will indicate boost when my vdo does. Then there are times when the stock guage says Iam in boost but my vdo is still at 0 psi. Is my map sensor bad , could it be hardwired wrong or is this normal. could someone please help me with this one
Re: 3 bar map sensor
I wouldn't trust the stock gauge. The reason to check about the making boost in the green vacuum area is to make sure you actually have a 3 bar map. (incase a dealer gave you the wrong part)
If yur lucky the part number is written on the underside of the MAP sensor. The 3 bar MAP part number is 16040749. I have two, one has the number one doesn’t. Also the receptacle (inside where the wires go) is black on the 3 bar and orange on the 2 bar. Either way you gotta take the thing out to look at it. While you're at it make sure the harness is fully connected.
Based on what I hear you say your MAP could be bad. Got Datamaster? I would not trust the factory gauge either way. Also check the hose that comes off the back of the manifold that goes down and tee’s off to the MAP and FPR. A leak, as in old hose, would really muck up the works.
SY2932
Administrator
Correct. However the part number has been changed:
"MAP sensors, stock 2 bar on left (orange/red connector) #16009886 and 3 bar on right (black connector) old number was #16040749 new # is #12223861."
After I installed the ultimate chip and aftermarket boost gauge in my truck over four years ago, I "forgot" that I even have one in the cluster (never look at it).
jwaller
Evil Genius/SyTy Guru
if you have a 2 bar map on a 3 bar chip it will run so ruch you shouldnt be able to drive it. it will flood the oil pan with gas and blow black smoke.
itlbtu2
DUDE you got a TATTOO
what would happen if you run a 3 bar map with stock chip or basic chip - not ultimate??
Maybe run a little lean or normal??
Just curious
