3 easy q's for those that know code 59
Mario65
Hotrodicus Supersonicus
1 I am using an electric fan and the fan relay is sent a signal from the negative wire from the intercooler pump. I dont want it to run the fan until 1 minute after starting Is there way to do it in code 59?
2 I want my extra fuel pump to turn on at about 5 psi or more automatically. Any way to do it in code 59?
3 My truck would crank very quickly when I first turned it over. I played with the timing some and some fueling at idle and it idles even better now but it seems the engine has to turn over a little more than I like or than it did before, beforefiring. It always starts just not immediately as before. Which way would you adjust timing or fueling for a quick fire?
thanks
turbodig
Re: 3 easy q's for those that know code 59
Yes you can, but I suspect you don't really mean that. Example- truck dies when hot, you restart... want it to wait a minute?
If you're not using the stock boost control, you could. Not sure *why* you would, as a Hobbs would be lots easier.
thanks
Depends, whether you're cold or hot.
Mario65
I
Ok 30 seconds? I just dont want it be running down the bat until it starts
I ll get a hobbs. Never saw one before.
It is slow to start hot and cold. Once its one it runs like never before.
thanks
