Will $59 work without a wideband input into the PCM? Just curious if I could use an external gauge and stock NB. I noticed a few tables that wouldn't work but other than that it should be good, right?
It will work but how will you know if your a/f ratio is right? Anyway just set your wideband correction enable temp as high as it will go...
