Thanks, Dig - here's what its about.....
Why, you ask? Doing some WG control experiments; the restriction built into the solenoid is too small for my use. Fabbed up a WG actuator using a *very* long, low compression spring, idea being to have more WG opening per psi of boost signal. Overall length is around 10", tight fit. Base boost is around 19psi - actually works well. I'm using the WG solenoid in a somewhat bass-ackward way, in that it bleeds pressure from the actuator via the normally foam covered vent port. Duty cycle here is same as stock; 100% = max boost (bleed open) & conversely. Sort of like a closed loop bleed valve. If I put a restrictor in the feed line to the actuator, boost control on a launched WOT pass is real good - BUT - big spike on downshift from cruise; that thing's got to react faster. Larger hole (restriction) fixes the spike, but loses part of the control from the bleeder. That turbo puts *lots* of air thru the boost control line!
Got a couple of solenoids ordered thru Dal; if I can gut one & remove the restrictor or "port it out", shouldn't need to use two. Plan B (two solenoids) is for use if Plan A doesn't work.
My "Long stroke" actuator is good in theory, but in practice, its a lot more sensitive to exhaust backpressure than a normal one w/ a short, stiff spring. Bleeder is used to decrease boost signal to it during long pulls, when the boost tends to fall, killing some or all of the backpressure effect. Turbo is TE60 / 14cm Mitsu w/ 1.4" WG.
Barry - Sy#26
Bangor, MI
