75lb High Impedance Injectors
denny
Anyone making a chip for these?
Can the current 75lb low imp chip work on the high imp injectors without the ecm mod?
I mean how different are they? I read somewhere that they respond a little slower but I can't find anything else.
Thanks
Denny
cloneman315
Re: 75lb High Impedance Injectors
i did the ecm mod and phill has a real nice chip for the 75s,we actually made it on the dyno on my truck,
denny
Thanks,
I already bought a phill 75lb chip just didn't get the ecm mod for low imp yet.
I guess my question is why mod the ecm for low imp when you can now get high imp 75lb injectors?
Thanks
turbodig
denny said:
Thanks,
Thanks
Who makes them? The only thing I'm aware of out there are 65# Hi-Z injectors.
denny
Here:
http://www.injectorman.com/Default....d=26&manufacturer=&level=2&list=0&sortfield=0
75 lb/hr (750 cc/min) High Impedance Injectors (Set of 8) These are High Impedance/Resistance (~12/16 OHMs) for use with the stock EEC computer (will work with aftermarket systems as well) by RC Engineering. High impedance injectors can be used in conjunction with the stock EEC to help vehicles pass emmisions, especially with today's 1996-present OBD-II computers and emmision testers. Using high impedance injectors also helps cut down the cost of upgrading your fuel system by allowing you to use your stock EEC computer and harness (chip/tuning required). No expensive aftermarket computer system required.
turbodig
denny said:
Here:
Interesting.... have yet to see a set of these in the wild.
I'd doubt the fuel delivery curve would be the same as a low-z set.
Heck, the 2-3 varieties of high-z 50s don't all flow the same, even with the same resistance.
LIL QIK
HELL YEA I GOT BOOST!
What's all involved in the ECM mod? I was under the impression it was just a matter of swapping in the drivers. But a little while back I saw another thread that made me think there was more to it.
I think qbnkiller does this mod for fee.
LIL QIK
Nope....I had already checked with him....said he doesn't do it anymore and to check with Nolan.
alwayscode390
pppssssshhhhhtttttttttttt
I have only been able to find 72# siemens HIGH IMP. .... would the tunes for a 75# and 72# be pretty much identical?! Thanks ---
turbodig
No.
It might get you running, but it would need a lot of tuning from there.
