7749 - Northstar
vortecfiero
looking for some info on this combo
If any one can point me in the right direction...
Its in a Fiero (of course) and we are considering
using a 7749 ecu when he decides to take the plunge
and go turbo
I think the main issues are
fireing the caddy DIS Ignition
and sorting out what injectors to use (will ours fit the caddy ?)
BTW Tthe northstar has been in the car for 3 yrs and it screams :D
but of course we want more!
turbodig
Re: 7749 - Northstar
and go turbo
This would be cool- have a friend who put an NA Northstar into a Corvair.
What vintage Northstar?
You should be able to run the 8 injectors, I would think... don't think
they're P&H. Even if they were, it's just a matter of a driver upgrade.
Caddy DIS had a Cam/crank sensor pickup arrangement... this wouldn't likely jive with the '749. Could use a FAST E-dist with the Caddy pickup
and a '730/'749... there's people out there doing that now.
I hate having to buy external controllers though (Not that the e-dist isn't
slick), so I'm of the mind to use parts from the GM bin.
There may be a way, if you're not afraid to do a bit of fabricating...
(Like make a trigger wheel) Could use the Quad-4 DIS, and use 2 of
'em.
May well be cleaner to do the e-dist, though, and less hair-pulling.
My .02,
Dig
vortecfiero
TurboTony said:
What year is the northstar out of?
I'll take a look at some schematics and see whats what
Tony
thanks tony...
Its a "95 out of a wreck but not sure of model
right now he's runing the origonal throttle body
with the huge iac motor (?)
but he has a newer throttlebody waiting in the wings that
utilizes a more generic iac and tps etc
the injectors are a standard looking (had another peek)
F
forcedfire
Guest
I don't mean to jack the thread guys but my question is along the same lines. I am trying to use the 749 ecm as an additional injector controller for my water/alky injection. :-?
I picked up a 749 and wiring harness from a wrecker and spent hours figuring it out.... finally got all the wiring figured out. The problems that I can see are..... my car is DIS (GM2.2L 1996) so I'm wondering what kind of signal is normally supplied from the distributor. I'm sure this is more complicated than I think it is but I wanted to tap into my factory sensors so I would have the 749 controlling only the WI. There must be some way to "lock" the pcm in open loop right? (since I will not have O2 feedback)
I don't want to have to use the edist, there must be some way I can get this to work..... it doesn't have to work properly (If you know what I mean?).... I just want the injectors to be driven when I want them to be... from there I wanted to simply adjust the pulse width. (I had originally planned a adj pressure switch on/off system but want to have more control over it (rpm & boost)
(PS. I got the PCM out of a 2.0L Sunbird so it is set up for that right now).
Thanx for the insight :D (I've been meaning to ask about this for months!!)
Tony Gibson
Winnipeg, Manitoba
turbodig
Tony Gibson
Winnipeg, Manitoba
Depends a lot on what type of DIS, and ECM setup you have.
If you've got the fully up-integrated DIS, you've got a long road ahead.
The ECM feeds the DIS from Cam and Crank pulses in that scenario.
If you have the Quad-4 style DIS, you're in luck. You should be able
to tap into the reference line off the DIS module.
Even if you have a crank/cam sensor arrangement, you still might be
able to do stuff. If your crank sensor pulses are even, you could simply
hook it up to a counter/divider and divide it down to what you'd need.
Once you've got a pulse, the rest is cake. You can hook up simple
resistors to fool the CTS, TPS, and MAT sensors. Varying RPM and
map will get you all the PW control you'd need.
You also have the option of integrating WB data into the 749 data stream...
Later,
Dig
F
forcedfire
Guest
Thanx for the help guys, the reason that I didn't want to hook up the 749 as my engine management was because I don't have any experience with flashing or programming chips (or engines!!). The plan was to try it out on the water injection and if I could get everything to work and get the hang of the programming then I would wire it in to control everything on my engine. The engine is currently set up with larger injectors and an adjustable Cartech FMU (input to the N/A MAP is limited to atmospheric pressure).
OK I'm trying to figure out what type of DIS I have, I know I have crank & cam sensors. Not sure if the crank pulses are even...... when I look at the "trigger wheel" on the crank there is two notches out of it in one spot and the rest are evenly spaced single notches (I guess this would be the reference but I don't know if the pulses are even or what?)
Looking at my wiring diagram.... the ignition control module has the following I/O:
-crankshaft position sensor signal (from sensor)
-Ignition Control A (goes back to the PCM, labelled ign control 1-4)
-Ignition Control B (goes back to the PCM, labelled ign control 2-3)
-Ref Signal (goes back to PCM labelled Crankshaft position reference)
-crankshaft position sensor ground (from sensor)
-Ref Low (Goes back to PCM labelled ICM Ref Low)
-Ground
-Ignition (+12V switched)
It looks like the camshaft position sensor is fed to the PCM......
Does this tell you anything? Thanx again!! :lol:
Tony
turbodig
-Ground
Tony
Hmmm... that's what I was afraid of.
Quick/Cheap test:
Tap into that Ref hi and ref low. Connect them to the '749 Ref hi/low.
Use the 3M tap-in connectors, if you don't like the idea of cutting wires.
Tie the 749 12v and the 749 IGN line to the ECM together, and tie them to
a 12v source. Hook up the 749 ECM main ground, too.
Hook a Diacom/Datamaster cable to the ALDL data line and a ground.
Power up the 749, you should be able to get it to link. You'll get a ton
of Trouble codes, which is to be expected.
Start the car. See if your RPM makes sense, and doesn't jump around
while the car is at a steady RPM. You might end up with RPM that's some
multiple of the actual RPM... that can be fixed.
This will get you "proof of concept", enough to investigate further.
If that works, you can fool most of the rest of the sensors with resistors
and the like.
Later,
Dig
