djwaggoner
Is that 'normal'? It happened on the 2-3 shift and to a lesser degree on 1-2 (only about 4*).
Started the run w/ knock count of 5 & ended w/ 8, so not that bad. I was amazed to see so much retard tho'.
Stock engine/turbo/inj, Ultimate T1-16 & boost max 17. 5. Inj duty cycle <90 & Zeitronix WB @ mid 11's.
Is there a problem I should be finding before turning on the meth and advancing timing?
Thanx
Thanx
