Re: 96 crank
Im just lookin to rebuild my motor. it died due to an oil pump failure, and took the crank with it. I need to find one and it seems that a junk yard is the easiest, im just wondering about interchangeability. I looked at that artical that you posted, and ill have to see if i can tell the difference between the two, although if the only side effect of using a rom vs a tos is a ticking noise that doesnt bother me, but ill take a close look at the flexplates and harmonic balancers. as the motor is being balanced as part if its rebuild, should all that stuff work out in the end?
