A/F ratio change when using methanol
It's just a six
Super Member
Hey guys,
I am looking into getting a methanol injection kit.
I am wondering how much change ( A/F wise ) you guys get when using your meth kits?
For example,,say you are running 12:1 A/F ratio ,,,then you inject the methanol,,,,,would
your A/F ratio go ritcher to say 11:4 ? more,,,less??
I have a Aquamist non adjustable 1S kit & the A/F ratios does not change much at all.
Thanks :tup:
turbodig
Re: A/F ratio change when using methanol
Hey guys,
Thanks :tup:
Wildly variable... depends on jet size.
You need bigger jets.
It's just a six
Super Member
Thanks Dig,,,
That example is not my A/F ratio,,,, mine was 13.8 last time out,,12.08 ET ,, really lean,,,not by choice.
How much variable can it be??? 1,2,, 3 points higher????
I am talking about with the engine responding & running good,,,not over doing the meth by flooding it out.
What is the typical jump richer a meth kit can give?:tup:...
VIPERRACING
Thanks Dig,,,
How rich it goes all depends on your jetting and meth mixture. Im a dealer for snow performance and have been installing & spraying for over a decade. I also run them on all my boosted cars, which is pretty much all my cars, lol, and they work perfectly and are easily fine tuned via the progressive controller. I just put a kit on the lambo and we ended up running the largest jets and just fine tuned it while driving it down the road. You really cant rely on the manufactures jetting recommendations because their never right because there are to many veriables such as jetting, % of meth to water mix, boost level, pump psi & pump speed. But to answer your question, yes you can drop afr by 2-3 points with just a meth kit and no other changes. You can just think of the meth kit as an extra fuel injector and that is exactly what it is. Also I would recommend that you get yourself a progressive controller. Hope this helps you out.
turbodig
Thanks Dig,,,
Yes.
Alky kits can take you from 12.8 to 10.0, depending on jet size.....
Aquamist was conservative size-wise, as they used water....
It's just a six
Super Member
Thanks guys,,,
I am thinking about the Devils own kit to purchase,,,the "Devil Doc" told me to use a M10 nozzle....
I see two members here have a Devils own kit & one person has D07 nozzle & the other is using a M12.
I plan on turning up the boost a bit to 24-26 psi range,,,,,my engine is 100% stock & max RPM is 4800.
On my Aquamist 1S system I ran 100% meth .
Aquamist makes a teflon type seal that can pump 100% meth.
I have never had to close the spark plug gap using the Aquamist system,,,do you guys think I need to w/a progressive controlled meth kit? I run the gap @ .035"
For a meth kit,,, I would need a 3 bar controller ,,,correct? I am using a 3 bar map sensor already.
I have a stock ignition w/a MSD 6A box.
Thanks:tup:
VIPERRACING
Thanks guys,,,
I plan on turning up the boost a bit to 24-26 psi range,,,,,my engine is 100& stock & max RPM is 4800.
Thanks:tup:
first off, running 100% meth is not safe. If your going to run 26lbs then I would close the gap to 28-30ths, maybe even less. No you dont need a 3 bar controller just because your running a 3 bar map sensor. just make sure that you get a progressive controller that goes up to 25lbs of tuning on the controller. The progressive controller has its own map sensor inside the box.
asrnj77
..hard to swallow
100% meth not safe? Why is that? In the buick world most people run 100% meth and it's recommended by many of the sellers.
It's just a six
Super Member
I think all the pump manufactures do not recommend 100 % meth even though they are 100% compatable/able to pump the meth.
Meth is highly flammable & when it is on fire,,,you cannot see the flame.
It's just a six
Super Member
Just curious what is the difference between a 2 & 3 bar controller?
Thanks.:tup:
VIPERRACING
creates too much heat inside the combustion chamber. TOO HOT=NOT SO GOOD.....
autoaddictions
The thing to rember when tuning for meth is your target afr will be more like 9.5:1. Unlike c116 witch you might like to see 11.5:1. Don't make the mistake of adding timing and boost then running a 11.5:1 ratio. You will almost certianly due damage. A head gasket at the least. I use a 50/50 mix of meth and water. At 30 psi I never see higher than 90 degree intake temps even on the hotest of days. Properly installed meth is an great tool for extracting more hp.
It's just a six
Super Member
Thanks for that.
I am curious if you had tried 100% meth,,all the GN guys run 100 %
autoaddictions
Thanks for that.
I have run 100% meth before. It actually slowed me down. I tuned my truck for C-116. How ever the inter cooler is just to small to keep the air intake temps below 180*. I use the meth as a liquid inter cooler. With it mixed 50/50 it will lower my intake temps below 100* no matter what the temp outside is. With 100% meth it adds to much octane and higher octane fuel burns slower. With 100% meth and C-16 the octane is in the high 120s. I don't trust the meth enough to run 30psi and pump gas. If the meth clogs or shuts down. BOOM!!! For a stock engine 40 meth 60 water be fine. I even use windshield washer fluid when im in a jam. It contains 30% meth. And is cheap!!
It's just a six
Super Member
Late responce,but have you run pump gas & meth & had it tunned for that combo? Less boost than 30 PSI,just curious.
Thanks
It's just a six
Super Member
OK guys,
been using more methanol & am really curious as to what A/F ratios most guys run when injecting a lot methanol?
9.5, 10.1 A/F ?,,, reading on a wide band.
I know it all will very a lot,but mainly just talking about a street car running 25 psi.
Thanks guys
Rick
TYTILIDIE
METH HEAD
Haven't made it to 25 psi yet buy I run straight meth and was shooting for 11.0-10.5. At those AFR's, I am getting no knock and temps can go from a solid 100* straight down to 60* in a matter of a second or two. One thing I can totally agree with Frank on is the trust issue. Before I wrecked my truck, I had a clogged nozzle. I noticed it in the AFR's and let off the gas. I am really hoping that the ISAC controller I bought will take care of all of that.
It's just a six
Super Member
Thanks for that.
I took my Sy out the other day & had set the A/F ratio to about 10.8 & it seemed to like that @ 24 psi,no knock.:tup:
Yeh,need a saftey feature that will tie into my AEM boost controller maybe?,,, to make it get base boost pressure ,when the A/F ratios gets too lean.
