about mechanical fan
The_Butcher
Butchery
i think i'm going to change my 1991 chevy s10 fan
i was looking in summitracing and i found that flex a lite mechanical fan .
my truck have the stock one i take alook at the suggested parts and i found spacers
and i think there is three sizes this make a littlebit confused i don't know now
should i use spacers since my truck stock and if yes what size should i take ??
and which fan should i take this one ??
http://store.summitracing.com/partd...907469+4294839058+4294838812+115&autoview=sku
or this one ??
and which spacer should i go with for the first one if it's gonna be my choise
http://store.summitracing.com/partd...0+4294924500+4294907469+4294839058+4294838812
finally should i stay with stock cluch fan ??or what ??
i wanna change the fan b/c when i use the truck without a/c the temp is noramal but when switch on the a/c it reach the half i don't know the number but the half of temp gauge
so please guys any help,information or suggestion will be more than appreciated
thanks
Norm
Re: about mechanical fan
What temp does it run at? Vehicles are usually set to run around the 190' mark. So if it gets a bit hot when your using the a/c that's not uncommon. If the needle doesn't go into the red, don't worry about it. Why waste money on something you don't really need.
turbodig
WyoSyclone said:
A lot of guys have switched to the shrouded plastic fan off of the Aerostar... more efficient and lighter.... I may switch to it, but may also see if the one off of my '02 Bravada will work (it's got a lightweight aluminum clutch!).
Here's a link to the Aerostar fan....
http://www.syty.net/forums/showpost.php?p=607552&postcount=7
The fan on my '99 montana van looks very much like it would fit. It's a dual-fan set up that could be staged to run the second fan only at high temps.
I like my stock fan, but the darn thing is really close to the shroud now with the new motor mounts. It might have to go...
Anybody know- is the astro fan the same diameter as stock? If it were even 1/2" smaller it would help me a ton....
The_Butcher
Butchery
do you think so norm ??
i'm worry about the coz my truck now has a brand new 4.3 262 engine that has never been in a car before i buy from a friend who buy from the dealer there was four engines that have been stored since 1989 in our GM dealer stores i was lucy to have the last one
there still some engines but not the 4.3 it's 454 fuel injected and 350 LT1
that's the story and thats why im worry about the
so as you said norm no need to be worry right
SY2455
70's Veteran
It is the same size as the stock fan. 19"
SY2455
70's Veteran
Aerostar???? I think you want Chevy Astro or GMC Safari. This fan was used on all of the following with the GM Part # of 15976889 . The number below is the AC-DELCO part #.
http://198.208.187.182/internet/VehiclePartFits.jsp?autosel=A&part=15-80712
The_Butcher
Butchery
Rookie said:
go electric. get two 12 inch fans, 160 thermostat, flush radiator, add new coolant and never look back.
:roll: i think that what will hapend will wait for some cash coz the ty sucked my wallet :tdown:
