Bad Ass Black Trucks
Alright, been doing my homework on Widebands and have been in about 10 different directions. So many choices; Innovate, PLX, Zeitronix, Motec.... NGK.
I was pretty torn. First thought was LC1, but then I heard about the problems guys had with the early ones. Looked at PLX and like the multi-gauge options. The Zeitronix has a neat display that you can get with different 'skins'. The Motex PLM is uber accurate but uber expensive. then I came across this thread: http://www.hptuners.com/forum/showthread.php?t=21019 My synopsis from that, the NGK AFX with the NTK sensor is the most accurate, budget WBO2.
Here is my question, can you use the NTK sensor with any Wideband system? Will it be as accurate as the NGK is?
The OBDII features and 'bling' that PLX, Zeitronix and Innovate offer are nice, but I don't have an OBDII vehicle that I want to tune. So interfacing with their software seems useless because I don't want to collect data in two places and try to mess with timestamps and different sampling rates.
What I really want to do is put in the wideband, feed the output to the PCM in my TY and log in datamaster. I also have the LT4 powered Sonoma which runs an LTX OBDI PCM that I want to feed wideband data as well. (You can send the output to the air conditioning pressure connector and scale the data for wideband, allowing you to collect in datamaster just like I would with the TY). I would also like to output to an Autometer narroband AF gauge to keep an eye on things when I am not logging (I have two sitting around). It can be done with a module for the PLX or by programming the output on the innovate, but I haven't found out if the NGK can be output to a narrowand gauge. Anyone know?
Right now I am leaning towards the NGK with the better NTK sensor. I like the accuracy it provides. But if I can't get the data to the PCM and my narrowband gauge, I may try the PLX with an NTK sensor if that is possible.
