accel DFI generation 7
warmpancakes
Anybody tried it yet? Just curious im looking into it they have added lots of features for boosted applications, knock progessive fuel for boost and such? Ken
bigtime
Sy-Ty Builder
It is the best. I just bought one for my ati supercharged small block chevy in one of my other cars. It is really user freindly being windows based.It makes your base fuel maps for you. Just go to the different set up screens and input you engine info. It also datalogs. It has a provision to run wideband o2 input ($900.00 option) but the beauty here is you can set your desired AF and let the computer do the work. I am currently waiting for my dual sync distributor to come in as i am going to run my smallblock in sequential mode. I don't think they make a dual sync distributor fo a V6 so you would have to run staggered batch. You really do not want to run a knock sensor. You need to spend some time tuning, tuning, tuning! Another added bonus is you can have different programs load with one key stroke. You can also buy or make another wire harness and swap it between cars. Only problem is it does not have a VSS input. It will be in my Ty by summer! I think you can go to MR Gaskets site and download the software
smeagol
They are in the middle of upgrading software versions once again.
I don't think wideband 02 closed loop is all it's cracked up to be; I never saw it work wonderfully in the FAST stuff, haven't heard of it doing miracles in the DFI either.
If I ever go aftermarket ECU again, it'll be AEM or Big Stuff 3.
I read the DFI v7 had TC lockup - if there is no VSS input, then it can't. Then, IMO, it really doesn't offer much over a FAST setup, which is proven, has a bunch of syty programs out there, and you can get a simple plug and play harness for it.
Sequential isn't such a big deal IMO either. Many Buick owners went to bank to bank systems in their cars, didn't notice anything.
I want boost control
I want datalogging of extra channels, for multiple 02's, EGT's, knock sensors
I want flexibility of tables, adjusting table axes, how the engine is controlled
I want the computer to know the mph, and be able to use it, for engine control, maybe traction control
I want cnp ignition support
DFI doesn't step up the plate for any of these, yet it is supposed to be a revolutionary jump from FAST - I just don't see it.
bigtime
Sy-Ty Builder
I need the sequential for driveability and emissions with big injectors on the street when i'm not under boost. There is no hp increase with the sequential. The lockup has a input for 4th gear and then locks by RPM. The wideband closed loop does give you a ton of help in the tuning process. yes nothing is better than a perfect program but the wideband does save a bunch of time. The vss does bother me also but for $900.00 The dfiv7 is really a good unit for the money. If you are using a dfi for racing there is no substitute for MOTEC.
smeagol
What are 'big injectors' ? Have you had a problem getting 'big injectors' to run on bank to bank ? I've tuned 55/75/83/96's in bank to bank mode; I've heard of 75's passing emissions in bank to bank mode. I've passed emissions on 50s on a stock motor in quasi-asynch batch mode.
We have no 4th gear sensor/switch in a Syty, so that's kinda useless :-?
Besides, I'd like to see mph control of the switch, as well as 3rd gear lockups.
I still say the wideband closed loop doesn't give you a TON of help; that's after using it, not just reading about it. I'd rather go open loop, tune using closed loop or just wideband 02 datalogs.
Yep, using the wideband 02 saves a ton of time, but we can do that on the stock computer for cheap now, as well as on FAST, or any of the quality systems out there.
I'm not arguing, just saying the DFI v7 isn't all people touted it to be months (or even years) ago.
FWIW, you can get a FAST plug & play unit for a Syty, with wideband 02, and big injectors, for around $2k I believe. That ain't bad, if you really need the datalogging/wideband and basic tuning by any FAST tuners.
On the other hand, I don't know anyone that has any DFI v7 syty programs, or a plug n play harness for DFI to syty's. All i've heard is issues with the software, bugs being updated, expensive wideband 02 replacement, EMIC's with no support, vendors who can't tell you anything about it, have nothing to offer you. Accel seems to be more worried about adding security to the system (locking out editing to the program, not being able to share calibrations) rather than any actual features.
Again, I'm getting to the bottom line on this. You want features - go check out an AEM or Motec system. You want easy dyno tuning by your average joe tuner on a Syty, get a FAST system. You know your stuff and wanna tweak on the cheap - use the stock system.
<rant 2 of the day, off> :wink:
bigtime
Sy-Ty Builder
I was looking at it for my smallblock chevy application.
, where it takes care of the 75lb injectors and 240 @.050 camshaft. I thought it would have some benifits in the typhoon also.
