i know this is probably a stupid question, but should does the distributor require 12v line for power or does it use 9v or 5v?
after that the next question i have is where should the power come from? the ecm ( i would guess yes if it is 5v or 9v) or a switched power source if it is 12v?
also, where does fast expect to see the hall-effect crank signal on a3/b3?
lastly, what is the brown (ignition control) wire? where does this signal come from if i am using edist? d2 (est/points ground/ref low)? or is d2 from fast j2 (distrtn reflow)?
once i have these questions answered, i _think_ i might have this figured out.
thanks,
chad
thanks,
chad
