accel dual sync distributor/ls1 coils qs/fast
protosy
i know this is probably a stupid question, but should does the distributor require 12v line for power or does it use 9v or 5v?
after that the next question i have is where should the power come from? the ecm ( i would guess yes if it is 5v or 9v) or a switched power source if it is 12v?
also, where does fast expect to see the hall-effect crank signal on a3/b3?
lastly, what is the brown (ignition control) wire? where does this signal come from if i am using edist? d2 (est/points ground/ref low)? or is d2 from fast j2 (distrtn reflow)?
once i have these questions answered, i _think_ i might have this figured out.
thanks,
chad
GEN3Typhoon
So did you get someone to answer the question if that dist can be set up so that the cam and crank signals don't overlap? I asked if they can be adjusted indepentdantly... could get no answer.
So I decided to clean up the engine bay and go with a crank trigger and the MSD plug.
Hope you do get this to work... I decided to just go the other route cause I could not find any good information .. also with the plug in the distributor instead of a dist back there... it opens up the engine bay a bit.
warmpancakes
Im sorry nick did I miss a question? the sensors cannot be adjusted seperately, but in the comming months will be releasing some new stuff including a coil on plus option for all cars (# of cyl selectable) and a odd fire box for the sys and tys.
GEN3Typhoon
Yeah... on a few occasions I pm'd you and I have posted the question on here a few times...
Sorry I did not have the time to get together with you last time I was in Michigan.. I am so cramped for time when I am there working.
protosy
pardon the ignorance, but why would i need to adjust them? because of the nonsense in edist of not having the crank reference cross the cam reference? if so this sucks.
i took the distributor apart this evening. stupid simple.
maybe i could have a friend of mine make up a new pcb that had slots to move the sensors in. would this even work? if you did adjust them, how would you know where you adjusted them to?
sorry for the simplified thinking here. i am still very new to all of this.
chad
GEN3Typhoon
If for some reason the cam signal and the crank signal cross.. .the ignition looses its place, so to speak...
You have to be able to adjust them so that no matter what you set your ignition table to.. you cannot make the spark signal cross over the cam signal.
This is over simplification of it... but that is basically it.
protosy
okay. so lets say i found a way to change the cam signal and retard it 50 degrees, but left the crank ref at zero. how would i tell edist that i did that?
or does it even care?
also, why couldnt i put the distributor as is in with 50* btdc and set the crank ref angle to 50* in fast? i realize that that would also roll back the cam signal to 50*btdc, but i would accomidate for the actual timing adjustment from the ecm, not the output of the crank signal. and from what i think i understand that would allow me to run upto 40* in timing right?
or am i _way_ off track here?
chad
GEN3Typhoon
See that was what I could not understand and could not answer from Accel.. but Ken is saying that they cannot be adjusted independently.. and I don't know how they are phased right now... so I don't know how you would set it up.
Here is the only site I ever found discussing the setup of them and it pertaines specifically to the DFI stuff. So not really any help. Like I said I decided to go another direction... I am curious to see if this would work though. But I did not want to spend 290 bucks on a dist no knowing and I certainly did not want to have to modify it once I bought it. I got the crank trigger and the cam plug for about 400 and I know it works.
http://www.rancefi.com/HeavyGraphics/gen_7_distributors.htm
And by the way.. from what I understand the Edist is technically stupid.. it is using the cam signal to be sure you are firing on the compression stroke that is all.
There are a ton of posts about this... search and you will find.
http://syty.net/phpBB2/viewtopic.php?t=23849&highlight=edist
Here is one good one.
protosy
i have read that post, about 10 times actually.
the way they say to install the thing is to wait for the cam signal light and the crank light to turn off. that would be falling edge for cam and rising edge for crank ( or at least that is what i have gleaned from their rediculous one page document ). when this cam fall/crank rise occurs that is tdc cyl1. i have had the thing apart and those two events occur _very_ close to each other.
their instructions go further to say to set the motor at tdc cyl1 (which i am pretty well certain will never work).
so i still think that what i said will work. set the distributor to tdc cyl1 (per instructions), but install it with the motor at 50*btdc, set crank ref to 50* in fast, that would allow me to run 40* of timing, with spark following the cam in as little as 10*.
this should work..... edist will be getting the corrected spark signal from fast, not the distributor and the cam signal will be statically at 50*btdc.
sorry for the rambling, but i am trying to get my head around all of this.
does that make any sense?
chad
warmpancakes
what im trying to figure out is why are you guys wanting the ls1 coils? ive personally seen that distributor run on 1400hp motors with no problems at 7000 rpm, what is the major benefit of the ls1 coils?also we could run coil on plug very easily with other coils like ford or such using a edis module (the ford one) and even could run a GN style coil pack. Ken
GEN3Typhoon
Well the main reason for me is not power.. the main reason for me is that I don't like having the disposable parts on the truck and these trucks are very tempermental with dist and modules and as it has been mentioned.. once we are running big boost and power, you have to run tight plug gaps.
I don't think this is for everyone.. I hope to make some big power with the truck and think this will go to reliability down the road.
Also... quite frankly, I am a tech junkie, this stuff is high tech and cleans up the motor well a bit.
