syclone3
Finally had a chance to test some chips on my beater Syclone on my Mustang AWD dyno.
Tested
4053
4175
KB piggyback with both 4053 and 4175
Hypertech piggyback with both 4053 and 4175
1991 ATR pitbull
1993 ATR pitbull
Wish I had an ATR stripchip.
Truck is as follows.
66,500 mile original engine
rebuilt stock trans, done before I got it. I did put valvebody kit in. Since old lady that had it, requested the trans be "toned down" when rebuilt.
ATR trans cooler
Ultra flow straight through 2.5 inch mufflers, yes it still has stock appearing twins.
2.5 inch testpipe
2.5 inch mandrel DP, heat wrapped, crossover is also.
KB FP regulator
255 Walbro
ATR cool air box
Magnecor wires, stock plugs
Atwater IC pump running all the time
Fan on back of heat exchanger
ATR aux cooler
manual controller after stock solenoid before WG canister
EGR blockoff plate.
Acell coil. Had it sitting around.
100 octane Rocket Brand unleaded, little C16 out of my race car, maybe 3 gallons to 17 of 100.
160 stat, stock fan.
J&S knock retard system, KB version. Not all wired up yet and functional.
Results were interesting. Made 16 runs today. Sure learned alot.
Do have a stock injector old style KB shootout chip. Might try it with all C16 or higher gas and the J&S functioning. I know on my other truck this chip picked up a whole lot at the track on some 120 fuel I had.
Will combine the two ATR and the one KB chip, best run of each, into one dyno graph and figure out how to post it up on here.
Lot of what I learned today will be helpful making a custom chip for this setup. Whats in there right now is pretty close to being perfect. Just shows that it takes many different chips to find one that is on the right track. Then making the best program with Code59 or such will perfect it.
I have an HKS standard gate on a stock crossover pipe thats 2000 degree coated. Might put it on tomorrow once I make a bracket to hold the stock gate shut. Not sure if the boost will be much better or flatter. But the difference in backpressure could help the stock turbo.
Power right now is 311 and torque is 459. Done in 3rd gear, not locked up. 20-21 psi dropping to 17 range.
Tested
4053
4175
1991 ATR pitbull
1993 ATR pitbull
ATR trans cooler
2.5 inch testpipe
KB FP regulator
255 Walbro
ATR cool air box
ATR aux cooler
EGR blockoff plate.
