The Devils Own Chariot
I think I have a failing walbro. It leans out in spots of the tune it shouldn't at like 10% tps. Then go way rich after I make a tiny adjustment. Then go lean again. I have not seen it fail at 80% tps. 50% and above just goes *RICH*. Also from day one you shut the truck off after driving, it will not start back up unless you hold the gas down a bit. Does this mean a temperature sensor? The tunerpro temp looks normal @ 180 degF. What sensor does the truck read from? Or is there a spot in code59 for hot startups that I need to tweak?
Im changing the plugs again just to be 100% sure. Fouled out plugs have always acted like a lean condition for me. Why is that? I have not checked fuel pressure when it acts up. I have things Im going to try. Im just digging for info that is point. This is tiring me out......
Oh and one more thing. I filled up my alkycontrol tank that comes with Don's kit. I see the stupid thing over flowing out the top of the cap. It came out of the cap at the breather. Uh... thats really dangerous especially if that runs down the exhaust. It cant be boiling in there is it?
