angle plugs with manifolds?
0260IN3
Engine Builder
Re: angle plugs with manifolds?
shoebox1.1 said:
i forgot to ask and im searching the forums with no luck... are angle plugs a known no no with factory manifolds?
You are correct.
shoebox1.1
i was just out working on the car tonite and the plug angle in relation to the gasket face on the head is NOT 90 degrees. my raised runner bowties point the plug down and angle. without the manifolds in my hand i cant say they would work or not. i wish there was somthing i could do ie clearance a little the manifolds and run short plugs. does anyone have a really good pic of factory plugs/manifold clearances? thanks for all the help
heres a pic of the motor in the car just for fun http://i143.photobucket.com/albums/r141/shoebox1_album/HPIM0629.jpg
heres another of the head http://i143.photobucket.com/albums/r141/shoebox1_album/HPIM0625.jpg
turbodig
Even if you could clearance it to get the plugs to fit, your plug wires/boots will be nuked in short order.
Looking at headers, or different heads.
shoebox1.1
well the heads are staying.. i bought this engine from a friend as a running engine that has gone 7.30's in the 1/8 all motor(@2800lbs). ive got some manifolds on the way..... they are going to get here... im going to bolt them up and stuff wont fit. then im going to be depressed lol and sell these perfect,no cracks manifolds
ghettosled
SYTY SUPERSTORE
they for sure will not fit with angle plug heads, and with the straight plug heads (aluminum brodix), the spark plug boot will be resting on the casting as the are pointed down more then stock..
shoebox1.1
i for sure believe everyone when they say these wont fit! i guess ill have a set for sale soon lol thanks everyone for your input
