Argent Sheen?
fauXGT
Brick Pilot
O.K., just spent the last couple of nights researching here and looking at pics here & Sportmachines ( and anywhere else I could find info). The painter thinks that argent cladding color (wa-8798) should be a flat to semi-flat color. My red truck had argent on the bottom originally, but that was 20 years ago. Remember it being glossy. Both my trucks have more of a gloss to semi gloss look on the existing spots. The teal one is really dull and faded on the cladding (179k miles), but under the bumperette was nice, shiney paint.
Since I have not seen in person pristine, original argent cladding yet on a Ty/SoGT, I was wondering what the senior members that have seen, or own a near new truck think.
Thanks in advance.
P.S. I've been told that the primer goes on very soon. I might be driving this by spring. lol.
TYHOGG
Re: Argent Sheen?
I bought my truck with 30k miles and original paint the cladding was shiny just like the rest of the truck.
Number219GT
Broke Status
Re: Argent Sheen?
IIRC all the argent cladding i've seen in person was as shiny as the paint was. :2cents:
p.s. they weren't repaints.
fauXGT
Brick Pilot
Re: Argent Sheen?
Shiny...I knew I was seeing the pics correct.
The painter thought that the pics I sent him had to have been ALL repaints.
Thanks for the replies.:tup:
DaveP
Re: Argent Sheen?
The original formula is a "low-gloss" single stage. Are you guys sure you're looking at original-paint cladding? It is not as "shiny as the body color". It may be glossy now, but it wasn't when new.
Here's a color chart that shows the "Typhoon Ground Effects" color. It's on the bottom row, second from left. PPG 35552, GM code 90 or BYB, Fisher #WA8798 Note that it says "LG". That's "Low Gloss". And it's "Gray Poly", not "argent".
Because single stage metallic are no longer available, you're going to have to use two stage. The gloss is in the clear. I spent a lot of time getting the gloss correct when I painted my red/gry. I did NOT use high-gloss clear. It was a mix of flat and clear to get about 80% gloss. It takes some practice panels to get the gloss correct. But about 9:1 flat/gloss clear is real close. Just a small proportion of clear in the flat glosses it up quickly. It's easy to get too glossy. There are about 20 pics of the car in this photobucket album. Pay attention to the DOI between the body color and the cladding. The cladding is duller.
Your painter is right. It is not "High Gloss". But it's not eggshell either. Kind of in the middle.
This is an old photograph that has been scanned, the car is dirty, but the cladding had never been off. This is PAS-applied cladding paint. Fairly low gloss.
DaveP
Re: Argent Sheen?
..... My red truck had argent .......Remember it being glossy. Both my trucks have more of a gloss to semi gloss look on the existing spots. The teal one i...... but under the bumperette was nice, shinny paint......
Since I have not seen in person pristine, original argent cladding yet on a Ty/SoGT, .
Hold on. Typhoons have Low Gloss paint. Sonoma GT's have semi-gloss. That's why you're seeing gloss under the bumperettes.
Sonoma GT's had the lower silver applied at Shreveport. This is coded on the SPID. ZY2, and the "L" will be different than the "U" color. The cladding was painted by PAS (presumably) to match. But the silver on the body was applied by GM.
The gloss is different for Typhoon and GT cladding.
turboj91
Re: Argent Sheen?
Dave's mad scientist way of mixng works and as he states, prepare let down panels and choose the gloss you want for your application. Write down each mixture so you know what to do when you make your ultimate and final decision.
You can also go to your paint supply jobber and have them show you result panels when a flattening agent is added to the standard clear coat. They should have formulas that tell what the end point will be (% of glass) and should also have color chips or panels to show the results. Same as with Dave's way, choose which one you want.
fauXGT
Brick Pilot
Re: Argent Sheen?
OK, so the 'original' paint trucks are so shiny because of waxing/polishing?
And the only truck other than Ty's I've seen is the '92 (?) Sy that is white/argent, but I don't know if it is original. It looks a little satiny/flat in the Homecoming 2007 video.
Thanks DaveP for the specifics & the recipe. And thanks to everyone else for the responses.
It's not a factory truck, but I'm trying to make it look factory, or better than. :D
P.S. I found an old post with DaveP giving the grille headlight buckets and center paint code as PPG 347811 dark argent flat clear. going to use that one also.:tup:
