Espritmike
How much should these cost and how important is it to install vs. stock?- Stock LB4 heads cam, boost, some mild upgrades (turbo 57mm, intercooler pump wired direct, adj. fp regulator, walbro pump etc.)
I connected ARP,they insist that I need the 233-3701. Do you think they just don't know our application and are playing it safe.
Are the bolts the same length and diameter as the other set, just different manufacturing and metal. It is hard to spend $150 when I can get new VR bolts for $12. $80 isn't as so bad.
My next question is about main studs. Again summit said that I had 4 bolt mains, and I said I didn't. I bought a 4 bolt main stud kit 233-5602 figuring I could use 1/2 the bolts. will this work.
