So who installed these caps if they didn't fit tight? Or did .1" just disapear during the engine running?
90% chance not the caps fault at all, but whoever installed, machined for them.
If the caps did not move in, then it must be the shops fault ?
Id say it was deff a clearance issue from the initial install and alignment.
I really dont see main caps/ especially programs getting got enough to expand causing a bearing to spin.
IF the bearing got that hot then there was a clearance issue or wrong bearing installed in the first place. With the oil going through there it should not heat up enough to cause it to expand that much.
I can see the cap cracking before that much expansion though.
I gotta laugh at this and be offended as an engine machinist all at the same time..:rotf:...If anything grew .100 in your engine due to heat, it would be a miracle....hell, the bearing shell is in the neighborhood of .100.....bad machine work.....nothing else.
