Bearing Clearance
I used the search and didnt really come up with much. What does everybody recomend for rod and main bearing clearances? Block is being machined for 4 bolt mains as we speak.
Also how much differance would they be between the 422 comp. and a coustom grind cam performance wise?
turbodig
Re: Bearing Clearance
.001 -.0015 on the rods.
.001-.002 on the mains.
If you keep to these, you won't need to get crazy with oil pump pressure. (< 60 psi)
As to the cam, it depends on your heads, and turbo.
Later,
