IGottaSy
I needed to fix a reverse light on my silverado 2500 with a flatbed to get it inspected. It was the weekend and the place selling the beds and accessories was closed. I started looking at the sealed light fixture and decided to cut a hole in the back of it big enough to change the light bulb out. Turns out it was soldered in place. Unable to splice the new bulb's contacts to the wires and use electrical tape or re-solder them in the fixture, I remembered my wife having a hot glue gun.
In went the new light bulb with contacts twisted around the leads. Got the hot glue gun ready and proceeded to squeeze the molten glue stick on the splices. It covered the bare wiring nicely and once cooled was as good as solder. Looking at the semi-messy gunk of melted clear plastic, it looked as if it would work far better than old electrical tape because dirty would not be able to penetrate it thus rendering useless as is the case with electrical tape. Electrical tape is ok at first but then the weather and dirt will eventually get into the spliced area and cause problem. It gets worse when the spliced wires are covered with the sticky substance on the tape and the tape just unwinds and falls off leaving it behind.
This was used as an alternative to the unavailability of a soldering iron as well. I also used the hot glue gun to attach the light bulb to the fixture because the molded plastic holder had become brittle and broke off. I don't think the bulb/splice will ever get hot enough to melt the glue unless I leave it in reverse longer than normal. It is in fact holding up nicely and I got it inspected.
All in all, this quick fix wasn't the best looking job but it worked beautifully and continues to work. I think I have found a better alternative to electrical tape. My wife will have to share her hot glue gun with me more often.
There may be some members who have been using this approach but it was new to me and I felt like sharing it since I had nothing better to do with my lil' free time before bedtime.
