Better than electrical tape
IGottaSy
I needed to fix a reverse light on my silverado 2500 with a flatbed to get it inspected. It was the weekend and the place selling the beds and accessories was closed. I started looking at the sealed light fixture and decided to cut a hole in the back of it big enough to change the light bulb out. Turns out it was soldered in place. Unable to splice the new bulb's contacts to the wires and use electrical tape or re-solder them in the fixture, I remembered my wife having a hot glue gun.
In went the new light bulb with contacts twisted around the leads. Got the hot glue gun ready and proceeded to squeeze the molten glue stick on the splices. It covered the bare wiring nicely and once cooled was as good as solder. Looking at the semi-messy gunk of melted clear plastic, it looked as if it would work far better than old electrical tape because dirty would not be able to penetrate it thus rendering useless as is the case with electrical tape. Electrical tape is ok at first but then the weather and dirt will eventually get into the spliced area and cause problem. It gets worse when the spliced wires are covered with the sticky substance on the tape and the tape just unwinds and falls off leaving it behind.
This was used as an alternative to the unavailability of a soldering iron as well. I also used the hot glue gun to attach the light bulb to the fixture because the molded plastic holder had become brittle and broke off. I don't think the bulb/splice will ever get hot enough to melt the glue unless I leave it in reverse longer than normal. It is in fact holding up nicely and I got it inspected.
All in all, this quick fix wasn't the best looking job but it worked beautifully and continues to work. I think I have found a better alternative to electrical tape. My wife will have to share her hot glue gun with me more often.
There may be some members who have been using this approach but it was new to me and I felt like sharing it since I had nothing better to do with my lil' free time before bedtime. :)
MadMike
Re: Better than electrical tape
Replacement pigtail(or trailer light fixture), shrink wrap, and solder. I've also taped and shrinkwrapped over that for a tighter covering. Crap over crap is still crap.
I hope your now working on SyTys like that.... GL
MikeRenz
not stock
jb weld is just as good as tig welding too!
no way hot glue is as good as solder. how can you get a hot glue gun in there but not a soldering iron.
IGottaSy
I am going to put it put to the test this weekend and report back with the results.
Let the roasting begin. Vote YEAH if you think/know it will hold up or NEY if you believe/know it won't.
No soldering iron used cause it was unavailable but now I have one. Keep in mind this is a reverse light that will see occasional use as it is my toe-truck/haul-mule/ranch-pig chevy 2500 junked out cheapo rig.
hatrik8
MacGruber!
They make liquid electrical tape. Probably would've been a better choice, but nothing beats soldering. I don't see how the hot glue would be much different though.
IGottaSy
Here is a tidbit I found on the good ol' 'net.
"Okay, here we go --these temps are for the art/craft type glue guns though, not for the industrial ones you might buy at a hardware store for various purposes:
.......high temp guns =385° F
.......low temp ones = 250° F
And this, in case it's of interest:
(low-temp glue guns are also recommended for use with polystyrene foams
...glue from high-temp guns will eat into the foam though it doesn't "burn" it, so its recommended to let the hotter glue from a high-temp gun cool down for a second or so before contacting the actual foam --can even extrude it onto something else like popsicle stick or something to allow it to cool)
...I believe even the high temp guns can be extruded onto rubber though, like inflated balloons"
MikeRenz
not stock
hot glue is not a conductor like solder is. so hot glue is not "as good as solder". You may have made a good connection of the wires, but you didn't make a good electrical connection.
Just becuase you don't use the lights often doesn't mean you should want to half ass the connection. Would have taken less time to find a soldering iron than to make this thread. :lol:
IGottaSy
You all are right. What was I thinking! I should have told the inspection station what I did. It's probably a safety hazard if I were to leave the truck in reverse for days! LOL.
Pics and test results to come by tomorrow. Hopefully the wires don't get red-hot and the glue melts and ... Dont even want to think about !! That plastic insulator on electrical wires must be reinforced with asbestos to stand against the heat a normal live wire produces. Our skin must be composed of similar material if we can touch these wires and not get burned!
SY2932
Administrator
Every once in a great while, a thread crops up on here that changes my life... I was working on a car many moons ago and it had a clear funky mess holding two twisted wires together. I just figured some hack had used silicone but looking back, I guess that it could have been from a hot glue gun. It may or may not have been the cause of the problem but it got replaced in my normal fashion. This is how I fixed the radio problems that I was having in my daily driver after I purchased it:
They cut the plug out of the wiring harness so they twisted and duct taped the TWO splices on EACH wire going to the receiver. Probably worked great as long as they had the car. I bet the owner's back is still sore from all the back patting that ensued afterwards. Didn't use butt splices or scotch locks and it works all day! BOOYAH :dizzy:!!!
DANG! I can't believe that I spent all my hard earned money on this stuff. I mean, this is the same equipment that I used when I was in the Air Force working on HF radios in Japan. What you don't see is my Fluke 77 series II DMM and Panduit GS2B cable tie tensioning gun. Still looking to score a Simpson 260 analog meter.
I'm REALLY floored that at no point in my $250,000 in training at Keesler AFB was I taught the *super secret* powers of hot glue guns. I now consider myself enlightened :idea:. Anyone want to buy a Weller variable temperature production soldering iron for cheap???
IGottaSy
:( Y'all jinxed it!! I don't think I like your gloomy outlook.
So, I decided to see how long until hot glue stick melted. Well, it didn't take long. In about 5 minutes of having the truck in reverse was all it took. The stuff started to melt around the bulb but not at the base where the splicing took place. It will eventually melt though when the heat of the glass reaches that area. :p
I'm glad I didn't spend $250K to learn that.
Hot glue NOT better than electrical tape. FAIL! :/
Haters are right, Boo!!
I tried to post pics or links to them but hot glue melted on my Internet connection. Not much to see but a sticky plastic mess. If anyone want to post for me, I could email them after I solder my 'net connection with $250k worth of edu and equipment.
IGottaSy
I vote pics or ban.
So impatient!
This one is after about 5 minutes of being on... Stuff was running off so I stopped. Got me a $5 soldering iron and some solder now. I would have probably spent more on the light fixture replacement from the store.
http://emob133.photobucket.com/albums/q74/Jackolivas/1362276332.jpg
This mess worked long enough to get that truck inspected. It is getting done right so relax.
http://emob133.photobucket.com/albums/q74/Jackolivas/1362255732.jpg
