MIGHTYMOUSE said:i ran my bs3 with esc for a while with my trans am.
you will need to have the box modified to use this, it does not 'come' as a standard option. its an extra black wire out of a grommet in the box outside of the main harness, or at least that how it was when i sent mine in to get moded for it.
also for mine to run two knock sensors i had to get two knock modules off of some other gm module, run the sensor wires to it, and give the modules power and ground and then tie the output signals together to the input wire on the box
i still have the modules and the sensors from my car out in the garage.
the above definitely applies to an ls1 and i would think still applies to the 4.3
i was still able to melt an engine while using it so i don't think its that beneficial. the two years after i removed it i have not melted an engine so i'm leaving it without the esc.
I always wondered this. How do you tune a turbo engine without a knock sensor? Just turn it up until it detonates, or what? How else could you ever reach maximum performance?MIGHTYMOUSE said:i was still able to melt an engine while using it so i don't think its that beneficial. the two years after i removed it i have not melted an engine so i'm leaving it without the esc.
MIGHTYMOUSE said:oh yea definitely make sure the spark bs3 says = spark at the crank (twist the dist to get it there) select the fixed timing box in bs3 to hold it at one spot say 10*
with boosted cars i normally set the timing to a figure i feel good about and then just roll the boost in till i get as fast as i want to go!
