Bif Stuff 3 knock control
denny
Anyone using the ESC kncok control option on BS3?
With the syty plug and play harness, stock knock sensor, what other wiring I have to do to get it to work?
I read a post that said it require a crank signal, how would you get a crank signal?
Thanks
Denny
brock1949
Its alive!!!
Re: Bif Stuff 3 knock control
I was wondering the same, I didn't read to far into it yet but seems like you gotta either run a dual sync dizzy, or put on like a crank trigger system. Neither is a cheap quick fix. How are things going? are you running on the BS3 now?
denny
Yes, I am runing with the BS3, it working good so far.
The two thing I don't like is not able to lockup the stock convertor and the KR function.
Everything else is working great, I am runing low boost and rich until I get comfortable with the tune.
Denny
MIGHTYMOUSE
Turbo F body guy
i ran my bs3 with esc for a while with my trans am.
you will need to have the box modified to use this, it does not 'come' as a standard option. its an extra black wire out of a grommet in the box outside of the main harness, or at least that how it was when i sent mine in to get moded for it.
also for mine to run two knock sensors i had to get two knock modules off of some other gm module, run the sensor wires to it, and give the modules power and ground and then tie the output signals together to the input wire on the box
i still have the modules and the sensors from my car out in the garage.
the above definitely applies to an ls1 and i would think still applies to the 4.3
i was still able to melt an engine while using it so i don't think its that beneficial. the two years after i removed it i have not melted an engine so i'm leaving it without the esc.
denny
Thanks, BS3 quoted me $100 to add the ESC option.
Someone said with solid mounts he was getting false knock and removed this function.
Denny
Tooky
Serious about performance
I always wondered this. How do you tune a turbo engine without a knock sensor? Just turn it up until it detonates, or what? How else could you ever reach maximum performance?
ViciousV6
400HP/550FTLB
I have never ran a ESC or Kock Sensor function and have never wasted a motor due to detontaion. That is why i hired someone who tunes these boxes all the time. The computer goes off AFR anyway to add and take away fuel. I will be @ the track next week for our first rental and should put down a 10 sec pass on pump gas with my GT35R turbo. Hopefully after burning the pump gas out, then on to race gas for some 20-25 lbs of boost passes for mid to low 10's passes.
You also need to make sure that your timing in the spark table is correct. Found alot of people don't change all the timeing marks and rev motor and check it. Its been off for most people with a BS3.
Ralph
MIGHTYMOUSE
Turbo F body guy
oh yea definitely make sure the spark bs3 says = spark at the crank (twist the dist to get it there) select the fixed timing box in bs3 to hold it at one spot say 10*
with boosted cars i normally set the timing to a figure i feel good about and then just roll the boost in till i get as fast as i want to go!
denny
My timing is sync with bs3, it was only retarded by 4deg. I got help from Nolan and Frank.
My tuck is a hobby for me and I am not a hard core racer.
I built the engine myself, the a2a, the water injection, dyi front coilover, everything I do my self.
Since I had it in 92, no one ever worked on it but me.
Except the trans , I took the trans out send sent it for rebuild.
I refuse to take it for someone to tune, I probably go back to the 50lb setup if I am not happy with the BS3.
Ralph, good luck at the track, love to see you get into the 10s.
Denny
Andreas
So you got fixed timing thru all boost and RPM?
MIGHTYMOUSE
Turbo F body guy
no, i was detailing the process to 'sync' the timing between the box and the crankshaft
timing is all over the place vs boost AND rpm once you click out of that 'test' mode
denny
after you sync the timing at idle by moving the dis and lock it down. You then sync the timing at high rpm by adding inductive delay.
Andreas
ahh I see,
So you lock up the timing as suggested 10* and then turn your dist until you read 10* at the damper
Where's that "select the fixed timing box in bs3" in the software.
Andreas
I think i found it
denny
You probably should download the latest version of the BIG software. www.bigstuff3.com
You check the "Enable Test Timing" check box.
Whatever value is in the Test timing {deg} ( 20 or 32, etc), you set your timing to match, then lock the dis.
Now Raise the rpm to say 4000 RPM and check the timing, is the timing moved from what you have at idle, you add Inductive delay(uS) uintil the timing is the same as it was at idle.
This is the way I did mines..
